JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications [IS200] What would you need for a reliable, safe, 220/225hp?
P.Lindblom
10-07-2020, 11:19 AM
Matt_C I must admit, I thought about the Altezza, but much prefer the smoothness of the 6 pot IS lump, and all the other gubbins in the car. Hmm, so either switch up to the 300, or chuck WAY too much money into the engine bay of the 200 I guess...
Also, a 6 pot engine sounds nicer than a 4 pot, unless the 4 pot is a boxer engine of course.
Edited 21-08-2012, 03:05 PM by P.Lindblom.
P.Lindblom
10-07-2020, 11:19 AM #11
10-07-2020, 11:35 AM
IS300 + v160 gearbox is similar money to a properly supercharged IS200. Better, similar horsepower.
10-07-2020, 11:35 AM #12
Matt_C
10-07-2020, 01:21 PM
What's a v160 gear box?
Matt_C
10-07-2020, 01:21 PM #13
10-07-2020, 02:18 PM
getrag v160 is the manual 6 speed box from a tt supra
10-07-2020, 02:18 PM #14
10-07-2020, 02:39 PM
The Altezza is a smooth engine I bet you wouldn't be able to tell the difference in everyday driving. Just don't get the auto box version they are seriously slow beasts.
10-07-2020, 02:39 PM #15
Matt_C
10-07-2020, 02:44 PM
is300_dino getrag v160 is the manual 6 speed box from a tt supra
Ah, gotcha. Seeing as they are both 2JZ's, I presume (possibly wrongly!) it's a simple swap?
FirebirdPhil The Altezza is a smooth engine I bet you wouldn't be able to tell the difference in everyday driving. Just don't get the auto box version they are seriously slow beasts.
To be fair, I never test drove an Altezza; I'm just going on what I've read in reviews and on the net. I know I instantly fell in love with the smoothness of the I6 in the IS, along with it's quiet and understated, yet lovely burble
Matt_C
10-07-2020, 02:44 PM #16
10-07-2020, 03:36 PM
Matt_C Ah, gotcha. Seeing as they are both 2JZ's, I presume (possibly wrongly!) it's a simple swap
a bit of moding is needed as the shifter holder needs shortening a little and you need to install the clutch peddle etc, and wouldl need a standalone ecu too, simple on paper expensive in reality lol, second hand v160 are around 3k, and around 6.5k brand new thats just for the boxConfusedhock: theres a fair few americans that have done it but they have all the manual setup there alreadyConfusedad:
10-07-2020, 03:36 PM #17
Matt_C Ah, gotcha. Seeing as they are both 2JZ's, I presume (possibly wrongly!) it's a simple swap?
It fits in the IS300 transmission tunnel without modification, you will need to get a prop fabricated and trick the ECU into thinking it's in drive.
10-07-2020, 03:36 PM #18
Matt_C
10-07-2020, 03:39 PM
Ah... Think I'd stick with the tiptronic auto box if I switched up to a 300 then Wink
Matt_C
10-07-2020, 03:39 PM #19
10-07-2020, 04:28 PM
el_bandido It fits in the IS300 transmission tunnel without modification, you will need to get a prop fabricated and trick the ECU into thinking it's in drive.
apparently propshafts from toyota sequiola's are a direct fit for the v160 and is300, saves on fabricating one up but with import costs probably not much between the prices
10-07-2020, 04:28 PM #20
Views 2,746
04-07-2024, 10:57 AM
Last Post by damtrx
Views 1,101
16-04-2024, 09:39 AM
Views 2,100
04-04-2024, 09:07 AM
Last Post by damtrx
Views 1,632
29-02-2024, 07:39 PM
Last Post by TheDieselDoctor
Views 565
29-11-2023, 09:27 AM
Last Post by phaebo
Views 598
30-04-2023, 12:16 PM
Views 1,011
27-04-2023, 06:34 PM
Last Post by oedipus
Views 1,422
19-06-2022, 06:39 PM
