JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 02 sensors
02 sensors
02 sensors
02-03-2018, 08:26 AM
You could change the sensor but you will need to get some one to reset the code.
Not sure if removing the battery will reset the code anyone know?
02-03-2018, 08:26 AM #11
02-03-2018, 08:29 AM
Lexusboy You could change the sensor but you will need to get some one to reset the code.
it seemed to clear it when we did it that way last time, even if i change it then just get lex to clear it when the fault has gone and hopefully they wont charge for it lol
02-03-2018, 08:29 AM #12
02-03-2018, 08:37 AM
I think your find the sensor around the manifold the the higher should be 1 bank sensor 1 then then 1 bank 2 sensor two is below that.
Then 3 & 4 are after the cat.
I see if i can find a digram some where to confirm.
http://img522.imageshack.us/img522/8813/o2diagram16.jpg
Edited 13-04-2010, 12:25 PM by Lexusboy.
02-03-2018, 08:37 AM #13
02-03-2018, 09:21 AM
Here's a link to another diagram, showing the sensors in-place on the car - linky
02-03-2018, 09:21 AM #14
02-03-2018, 09:23 AM
Lexusboy I think your find the sensor around the manifold the the higher should be 1 bank sensor 1 then then 1 bank 2 sensor two is below that.
so its not the one i replaced last time, which is bit of justification to the other sensor. just got to try and find a replacement at a sensible price now. thanks for your help.
02-03-2018, 09:23 AM #15
02-03-2018, 09:24 AM
Anyone know if there are difference between the 02 sensor on the IS200 & IS300?
02-03-2018, 09:24 AM #16
02-03-2018, 09:27 AM
Lexusboy Anyone know if there are difference between the 02 sensor on the IS200 & IS300?
Yeah they are not the same part numbers. eBay US will probably be the best place, given all the IS300s over there.
02-03-2018, 09:27 AM #17
02-03-2018, 09:42 AM
thanks for the extra diagram steve, just sent jay_R a pm to see what sort of a price he can do before i spend out to the americans lol.
02-03-2018, 09:42 AM #18
russelllinn
02-03-2018, 12:08 PM
Jay is better than ebay as it is def genuine and cheaper than UK. Bank 1 sensor 2 is the same 1 I had go, the banks are the other way round to what you would think, if you are looking at the car from the bonnet then bank 1 is the farthest set of three!
russelllinn
02-03-2018, 12:08 PM #19
02-03-2018, 12:17 PM
cheers mate, just waiting for a reply from jay.
02-03-2018, 12:17 PM #20
Views 1,273
29-11-2019, 10:22 PM
Last Post by Bandit
Views 815
22-06-2019, 06:02 PM
Last Post by Phil01
Views 1,360
15-05-2019, 09:30 AM
Views 690
31-05-2018, 11:34 AM
Last Post by cameron
