JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications injector help
injector help
injector help
06-10-2018, 02:31 PM
LEX11S seen some injectors on e-bay for £295.39 23.00 postage this is for 6 listed for are cars made by denso and they are 550 cc? any good
Depends if they are the right sort of injectors for the car, e.g. fitting, number of holes, etc, etc.
06-10-2018, 02:31 PM #11
LEX11S
06-10-2018, 02:36 PM
well there blue and have 4 holes in them if you go on e-bay and type in th550a they are at the bottom sorry i carnt post links dont know how too Blush
LEX11S
06-10-2018, 02:36 PM #12
06-10-2018, 03:03 PM
Sounds promising. Those aren't the Power Enterprise ones, and I suspect the picture is just a stock pic and not necessarily exactly what you're getting. But if they say in the ad they're for an IS200 with 1G-FE then they should fit.
I would ask the seller to confirm that the electrical connectors are the same as the IS200 uses though.
From a quick Google, those injectors seem to be used on the RX-8.
06-10-2018, 03:03 PM #13
LEX11S
06-10-2018, 03:09 PM
ummmmm i will ask could well be that you can use rx8 ones then?
LEX11S
06-10-2018, 03:09 PM #14
LEX11S
06-10-2018, 03:13 PM
message sent wait for reply
LEX11S
06-10-2018, 03:13 PM #15
LEX11S
07-10-2018, 12:37 PM
Right got a message back they said that it will fit the is200 without having to do sweet FA.
looked up the part number looks like they fit an rx8 as well found a pic of one on a injector web site (injector-rehab) heres the spec
528cc not 550cc
50lb/hr
2.25 bar rating
14.8 ohms
takes the denso connector
hope this helps also they are £293.81p for 6
LEX11S
07-10-2018, 12:37 PM #16
528cc not 550cc
50lb/hr
2.25 bar rating
14.8 ohms
Views 664
09-09-2023, 06:48 PM
Views 604
15-09-2020, 10:34 AM
Last Post by liquidlazer
Views 879
09-01-2019, 07:10 PM
