JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications changing 1G-fe internals affects supercharger?
03-11-2018, 03:57 PM
Yes jay is right mate. Bad mapping causes problems with internals. Why don't use denso injectors like i have done. plug and play mate no need to drill holes...
03-11-2018, 03:57 PM #11
seecarr11
03-11-2018, 04:13 PM
so all you did was change the injectors? interesting. what piggy back r u using?
seecarr11
03-11-2018, 04:13 PM #12
03-11-2018, 04:19 PM
to late as i'm running the 1g gte ones now which are denso 315cc and it's ok for what i'm needing. and e-manage blue just now but going up to ultimate soon
03-11-2018, 04:19 PM #13
seecarr11
03-11-2018, 05:29 PM
too late for me as well cause i already bought a 1G-GTE with the 5speed gearbox
so both injectors are around the same (310cc ) but are both high impedance?
also i think i'm going to go with a greddy ultimate like dimis, but i was wondering, seeing as the silver box has slightly different operation from the black and jay is running just great with only the injector upgrade, would it be safe to continue to use it for this app seeing as i don't have to get into changing internals? at the moment my a/f is around 12.- 13.4.
seecarr11
03-11-2018, 05:29 PM #14
03-11-2018, 05:59 PM
The denso injectors i have used have the same impedance with the oem. you could also use altezza injectors mate (340cc). Here are the specs:
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
Resistance - 14 Ohms (High impedance)
Denso number - 23250-74220 (Toyota number 23209-74220)
03-11-2018, 05:59 PM #15
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
why not just do a engine swap. it fits like a glove and the gearbox match up. run turbo's and stock ecu with piggyback and just boost it up. and yes the injectors are the same.
03-11-2018, 05:59 PM #16
seecarr11
03-11-2018, 08:18 PM
like sparkystav? i thought about that too but i prefer the charger setup and i've grown fond of my cruise control :blushing:
besides if i can get the power i'm looking for without messing with the car too much why bother? as it stands right now, you guys have inspired me, apprently, all i have to do is swap the injectors.
seecarr11
03-11-2018, 08:18 PM #17
LEX11S
05-11-2018, 01:44 PM
jay_russell see me and rabster both have 1gfe internals and run 250+ without a problem. i'm going up to 320 soon on standard 1gfe internals then i will change them out to hit 400,my turbo is good for more but i will need to change ecu and injectors for that. i think you will find that bad mapping was to blame for people saying there internals failed. you need to do it right.
Me too iam running turbo stock internals and 260hp no probs
just about to up the go with new injectors as long as the map is right you shouldnt have a prob. :biggrin:
LEX11S
05-11-2018, 01:44 PM #18
seecarr11
05-11-2018, 02:27 PM
you guys are getting 250+ at what psi?
seecarr11
05-11-2018, 02:27 PM #19
05-11-2018, 02:29 PM
LEX11S Me too iam running turbo stock internals and 260hp no probs
The big part of that statement is as long as the map is right.
Bad mapping kills engines fast.
05-11-2018, 02:29 PM #20
Views 3,082
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,384
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 786
05-04-2024, 07:48 AM
Replies 24
Views 2,588
12-01-2024, 05:42 PM
Views 510
03-01-2024, 07:08 PM
Views 336
28-12-2023, 04:46 AM
Views 716
02-12-2023, 07:46 PM
Views 748
04-11-2023, 11:43 AM
Views 243
30-07-2023, 07:38 PM
