JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza deactting & lambda sensors
spud1973
14-05-2019, 03:13 PM
Big thanks to Stav for the little box of tricks if I see you at a meet I owe you a pint:thumbup:
spud1973
14-05-2019, 03:13 PM #11
15-05-2019, 05:05 AM
I replace my precat manifold with a DKNE exhaust manifold without precats and never had a problem of check engine light or any code errors. When I fitted my HJS 200 cell sport cat the check engine light turned on and i solved the problem by fitting a mechanical spacer to fit the sensor a bit further from the exhaust gases. It is being working fine with no code errors for more than a year. I am not sure if this solution will do if you totally remove the middle cat.
15-05-2019, 05:05 AM #12
RichyUK
15-05-2019, 06:41 AM
spud1973 Big thanks to Stav for the little box of tricks if I see you at a meet I owe you a pint:thumbup:
+1
RichyUK
15-05-2019, 06:41 AM #13
+1
15-05-2019, 09:30 AM
not a problem lads, glad i could help
15-05-2019, 09:30 AM #14
Views 1,270
29-11-2019, 10:22 PM
Last Post by Bandit
Views 1,194
10-07-2019, 09:02 AM
Last Post by Jimbob-T-Lex
Views 600
05-07-2019, 06:05 PM
Last Post by Kerja
Views 813
22-06-2019, 06:02 PM
Last Post by Phil01
Views 1,178
17-05-2019, 12:49 PM
Views 688
31-05-2018, 11:34 AM
Last Post by cameron
Views 1,755
02-03-2018, 12:17 PM
Last Post by is300_dino
