JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications The rebuild begins....
22-06-2019, 05:37 AM
Good work mate. Wouldn't fancy doing that myself!
22-06-2019, 05:37 AM #11
22-06-2019, 05:51 AM
Stoney Good work mate. Wouldn't fancy doing that myself!
I'm pretty much cr@ping myself as well lol. I think also by the time I've purchased all the tools I need, it would have been cheaper to ship it to the USA and have someone else do it.
And if I did that, I'd be half way to the cost of a new head unit.
But hey ho...at least this way I get to pull the thing apart, clean it all myself, powdercoat it in whatever colour I want (fake chrome, silver or matt black?) and then seal it up good and proper with some new gaskets and liquid sealant.
22-06-2019, 05:51 AM #12
22-06-2019, 06:10 AM
Good work mate,
and dont worry the tools will come in handy! you could even offer a service to other UK/Europe based people which the same chrager!
22-06-2019, 06:10 AM #13
Good work mate,
22-06-2019, 06:18 AM
Sparkystav Good work mate,
Yeah. At the very least I can probably make use of the gear puller when I get around to changing my water pump soon. I'm not sure how tightly that pulley is wedged on the pump. I might switch out the rest of my pulleys for shiny anodised ones at some point too Wink
22-06-2019, 06:18 AM #14
22-06-2019, 06:25 AM
every cloud..... lol
22-06-2019, 06:25 AM #15
22-06-2019, 06:34 AM
Brave man Jim :thumbup:
Nothing like getting stuck in. Or so I'm told. :biggrin:
22-06-2019, 06:34 AM #16
22-06-2019, 08:06 AM
Sparkystav every cloud..... lol
Either that, or "any excuse"!
22-06-2019, 08:06 AM #17
22-06-2019, 09:30 AM
Well if I break it (which I'm hoping I won't), I'll be forced to go out and get a P1SC-1 charger Wink
22-06-2019, 09:30 AM #18
23-06-2019, 05:43 PM
Made a bit more headway today in getting this ****** apart...
Started off by giving the top a clean with some brake cleaner...
[Image: l_cleantop.jpg]
Then used yet another new tool (a mini bearing puller) to get the bearings off both sides of the oil slinger and the smaller bearing off one side of the crank shaft.
[Image: l_pulledtop.jpg]
The larger pulley required the full gear puller setup used to get the pulley off. But it came off eventually...
[Image: l_bearing.jpg]
Then I moved on to the bottom half of the unit. The cradle for both the oil slinger and the crank bearings needed to come off. Was a pain in the a$$ as they were both pressed on. Also cleaned it all up:
[Image: l_bottom.jpg]
[Image: l_bottomclean.jpg]
23-06-2019, 05:43 PM #19
Phil01
23-06-2019, 07:43 PM
Have you found any wear in the bearings or housing at all Jim
Phil01
23-06-2019, 07:43 PM #20
Views 698
12-12-2021, 10:06 AM
