JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! Opinions on new build
12-01-2021, 08:52 PM
UZZ30 seats are 20kg, 31 or 32 are way more (40+ each). Remember the base model V8 was the cheap Soarer model so it doesn't have any toys.
12-01-2021, 08:52 PM #21
12-01-2021, 08:58 PM
soarer is a good choice actually because of where the fuel tank is located. Pretty sure it makes it easier for track regulations.
12-01-2021, 08:58 PM #22
reco2k
12-01-2021, 11:36 PM
Had a quick look and it seems that 1800kg is the popular number but as you say 100kg can be lost in the seats take out the air con heater matrix eroneous wiring and could pheasibly get it to 1600kg so with a vvti 1uzfe on throttle bodies it would be around the 400hp mark giving 250hp per ton then if it was charged that will jump hugely.
On the other hand start with an is200 and you would be looking 300hp per ton n/a
So many choices lol currently sorting a unit with my friend and as soon as that is secured i will be buying a shell/donor car
Ross
reco2k
12-01-2021, 11:36 PM #23
Ross
13-01-2021, 07:54 AM
is200 is a very good chassis. If you just want a track car, put a 13b into an MX5 Big Grin
Edited 24-02-2013, 11:40 AM by el_bandido.
13-01-2021, 07:54 AM #24
reco2k
13-01-2021, 10:41 AM
el_bandido is200 is a very good chassis. If you just want a track car, put a 13b into an MX5 Big Grin
I want something a bit different tho and i have wanted to do this conversion for so long now i think now i have the opportunity i have to do it :-)
Ross
reco2k
13-01-2021, 10:41 AM #25
Ross
13-01-2021, 11:18 AM
yeah I'm just being silly mate! V8 IS chassis is where it's at.
inspiration: http://youtu.be/y_DHSTnV8ks
skip to about 3:30
13-01-2021, 11:18 AM #26
skip to about 3:30
reco2k
13-01-2021, 03:04 PM
I did think about going all out n doing the 430 instead of the 400 along with the sequential box
Ross
reco2k
13-01-2021, 03:04 PM #27
Ross
13-01-2021, 03:20 PM
the 6 speed semi auto from the late GS/LS430? aka the A761e? That's the conclusion I came to.
430 stuff is expensive though!
13-01-2021, 03:20 PM #28
reco2k
13-01-2021, 03:23 PM
el_bandido the 6 speed semi auto from the late GS/LS430? aka the A761e? That's the conclusion I came to.
Yeah that was the one we discussed before. Just had a quick look on lextreme and they do direct comparisons between the 1uz and 3uz and the 1 is a much stronger engine but needs the vvti or 3uz heads on it to reach its true potential. As you say tho the engines cost a lot more i could get 3 1uz engines for the price of 1 3uz...
Ross
reco2k
13-01-2021, 03:23 PM #29
Ross
13-01-2021, 06:09 PM
http://www.driftworks.com/forum/parts-sa...-sale.html
purchase this before I do.
13-01-2021, 06:09 PM #30
