JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications changing 1G-fe internals affects supercharger?
05-11-2018, 03:41 PM
i'm running 7.2 ps1 or 0.5 bar just now
05-11-2018, 03:41 PM #21
seecarr11
05-11-2018, 05:39 PM
only 7 psi gets u into 250 range? impressive:thumbup:. is that at the wheels or the crank?
anybody have an idea of the max psi the eaton m62 can generate and what size pulley i'd need to get 7-10 psi?
also, forgive my ignorance, but a mapping a file u can copy and paste to any greddy ultimate? it would be nice to have a base map that we can tweak from
seecarr11
05-11-2018, 05:39 PM #22
05-11-2018, 06:08 PM
thats at the wheel.it goes to show what a good turbo will do. mine blew up when the mapper was mapping it. he then contacted a turbo company here with the spec of the car and what flow rates he would like in return and the custom built it to do the job he was after for me. i was shocked a bit when i was getting 100 bhp from 7psi so that gives me a lot of room for playing with after the internials have been changed.
05-11-2018, 06:08 PM #23
seecarr11
05-11-2018, 08:21 PM
yours blew up:blink:? what do u mean? you're on to your second turbo? and gord i have a 160mm pulley, 5 rib that i got from stav a while back, its supposed to up the boost to 7psi (i think) can anybody confirm?
seecarr11
05-11-2018, 08:21 PM #24
05-11-2018, 09:06 PM
well i got one of these cheap turbo's that was made in china with the kit i brought and when he started to pump up the power in just blew. broke the shaft and both fans. leaving bad damage. hence the reason i had a custom made one. so the first one lasted 3 hours and a good lesson about buying good parts and not cheap ebay stuff.
05-11-2018, 09:06 PM #25
LEX11S
14-11-2018, 09:18 PM
seecarr11 you guys are getting 250+ at what psi?
iam running .05 bar to make 260hp
LEX11S
14-11-2018, 09:18 PM #26
14-11-2018, 09:22 PM
I'm getting 282 on mine with standard internals unsure on presure at the mo lol
14-11-2018, 09:22 PM #27
seecarr11
14-11-2018, 10:14 PM
What piggyback are you all using? I know stav's running a full stand alone with his gte
seecarr11
14-11-2018, 10:14 PM #28
seecarr11
14-11-2018, 10:18 PM
Oh sorry merry Christmas and best wishes for the new year ladies and gents Smile
seecarr11
14-11-2018, 10:18 PM #29
15-11-2018, 08:24 AM
for sure you will need a new piggyback ecu and injectors as the oem injectors max out at 215 and a fcd will only work for small power increase. you can use a emanage blue and some denso injectors(toyota) the blue can handle the kind of power your going to get from the compressor with injectors under 400cc but if your going to put on big injectors or that the you will need the emanage ultimate.but you might want to look into a cooling system for the compressor if your going to run it super hot. water to air cooled system or air to air
15-11-2018, 08:24 AM #30
Views 3,082
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,384
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 786
05-04-2024, 07:48 AM
Replies 24
Views 2,588
12-01-2024, 05:42 PM
Views 510
03-01-2024, 07:08 PM
Views 336
28-12-2023, 04:46 AM
Views 716
02-12-2023, 07:46 PM
Views 748
04-11-2023, 11:43 AM
Views 243
30-07-2023, 07:38 PM
