JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lexus Misfiring, please Help!!!!
greeny
24-04-2019, 04:26 PM
No i had this issue, i had all the plugs changed first, this will then need a reset from this if it still misfires then look at coil packs after you have had a pressure test done on the head.
[SIGPIC][/SIGPIC]One chance in life - LIVE it to the full
:drink: :thumbup:
greeny
24-04-2019, 04:26 PM #21
:drink: :thumbup:
jayson2323
24-04-2019, 05:42 PM
thanks Gord for the info. Is there any reason I should have a pressure test?
jayson2323
24-04-2019, 05:42 PM #22
24-04-2019, 05:46 PM
Pressure tests are generally for cars with a blown headgasket mate, so I don't think so.
24-04-2019, 05:46 PM #23
24-04-2019, 05:51 PM
If you can get over to the Milton Keynes / Buckingham area I've got an OBD2 reader. Am happy to run through tests with you but I don't have much free time over the next week!
24-04-2019, 05:51 PM #24
jayson2323
25-04-2019, 04:16 AM
thanks Dark I thought that but was not too sure. Toxo I appreciate the offer but not sure if it good for the car to drive that far in its condition?, I should get the code today after 4pm which is when I have a mechanic coming to read the codes, I will obviously ask him to clear the codes first then go from there then Iwill post the codes on here
jayson2323
25-04-2019, 04:16 AM #25
jayson2323
25-04-2019, 04:49 PM
Guys the mechanic cam today and he cleared the codes and the engine light came straight back on and the code is P1305 which I looked up to be the igniter circuit fault bank 2 so moved it to bank 5 and the fault moved to bank 5. I had a spare coilpack from the issue I had last year with a coil pack and put that in place of the faulty one and voila misfire has gone thank goodness, thanks guys for your support and suggestions, without your help I would have probably spent money unnecessarily yesterday, glad it is fixed now.
jayson2323
25-04-2019, 04:49 PM #26
25-04-2019, 04:51 PM
Glad it's fixed for you matey, glad we could all assist also Smile
25-04-2019, 04:51 PM #27
mr-p
25-04-2019, 05:20 PM
before you go and buy a code reader check the air gap on the spark plugs and the condition of them, could also test the resistance of the coil pack/leads with a multimeter, if you get a high resistance the current will not flow and will not be able to jump the gap at the spark plug. if you can lift the coil packs away from the plugs while its running you may hear the offending coil with the spark being very weak, you may find the one that is down and not have to waste the moneySmile
mr-p
25-04-2019, 05:20 PM #28
mr-p
25-04-2019, 05:22 PM
lol i posted to an old thread :blushing:
mr-p
25-04-2019, 05:22 PM #29
Phil01
25-04-2019, 05:35 PM
^^^:Fish:
Phil01
25-04-2019, 05:35 PM #30
^^^:Fish:
Views 1,667
06-11-2023, 07:38 AM
Views 631
18-10-2022, 07:53 AM
Views 565
04-09-2022, 01:09 AM
Last Post by Ratchet
Views 959
03-09-2022, 04:53 PM
Replies 35
Views 9,425
04-08-2022, 10:23 AM
Last Post by cjoseph
Replies 128
Views 10,554
20-08-2021, 02:58 PM
Last Post by Fry-Up
Views 2,153
17-06-2020, 05:41 PM
Views 629
25-04-2020, 06:05 PM
Last Post by jasons
Views 580
19-03-2020, 03:39 PM
Views 761
26-02-2020, 02:38 PM
Last Post by rosey1955
