JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications The rebuild begins....
Pages (4): Previous 1 2 3 4
09-07-2019, 02:32 PM
#31
Text on its way.
09-07-2019, 02:32 PM #31
Text on its way.
09-07-2019, 02:36 PM
#32
Dark Samurai Text on its way.
LOL. This one isn't going back on my car. Good news is that my new one has arrived at at a friends house in the USA and they will be forwarding it on to me today.
Have also ordered my new radiator and lightweight pulleys so I can put it all on in one go Big Grin
09-07-2019, 02:36 PM #32
09-07-2019, 04:06 PM
#33
Ok so final update.....
Took some time but I found a new o-ring big enough for the supercharger housing....
[Image: s_img_0584.jpg]
Also a new Oil seal for the impeller shaft...
[Image: s_img_0585.jpg]
...and one for the pulley shaft...
[Image: s_img_0586.jpg]
First set of bearings in. These are the high speed ones on the impeller shaft..
[Image: s_img_0587.jpg]
And then the oil slinger slotted in nicely...
[Image: s_img_0588.jpg]
All coming together. Everything in place and mated up nicely ready for the housing to go back together...
[Image: s_img_0591.jpg]
Used some high temp sealant on everything to make sure there would be no oil leaks from any of the bolts or seals. Back together...
[Image: s_img_0593.jpg]
[Image: s_img_0595.jpg]
And impeller back on...
[Image: s_img_0596.jpg]
Job done!
09-07-2019, 04:06 PM #33
Job done!
Phil01
09-07-2019, 04:12 PM
#34
Good work Jim, quite a big job to take on, well done
Phil01
09-07-2019, 04:12 PM #34
09-07-2019, 04:16 PM
#35
Phil01 Good work Jim, quite a big job to take on, well done
Thanks mate. I imagine it would be 10x easier if I'd had the proper tools for pulling bearings and pressing them back on. It was quite a pain in the backside trying to find ways of pushing the bearings back on without exerting any stress on the outer ring of the bearing.
I also pulled a bearing and it exploded into a shower of balls, leaving behind the centre ring which I then needed to dremel off carefully :Chair:
09-07-2019, 04:16 PM #35
speedfreek
09-07-2019, 05:15 PM
#36
Great job here mate, I wouldn't have the confidence to attack something like this!
speedfreek
09-07-2019, 05:15 PM #36
Views 580
12-12-2021, 10:06 AM
