JapCarForum Cars, Cars, Cars! General Car Maintenance IS200 problems already...
RSTurbo50
12-02-2020, 09:40 AM
I purchased my 2000 W Lexus IS200 Sport last weekend. The car has been running fine. However, last night I used the keyfob to open the doors on the car. Absolutely nothing, no response. I used the 2 spare keys and again nothing. The red lights on the fob come on but I am unable to open the doors.
I changed the battery on one of my fobs but again no luck, simply cant open it.
I opened the drivers door manually with the key and the alarm goes off for about 20 seconds then stops. Can anyone shed any light on this and what I need to do to get the car open without the alarm screaming.
Thanks
Stuart
RSTurbo50
12-02-2020, 09:40 AM #1
Thanks
Stuart
12-02-2020, 10:23 AM
could be that the keys have been forgotten by the car or that the signal was blocked.
have you tried driving somewhere else and seeing if they work?
if not you'll have to reprogram the keys, there is a guide on the forum to do that though
12-02-2020, 10:23 AM #2
12-02-2020, 10:39 AM
agree with above may have to reprogramme the keys
12-02-2020, 10:39 AM #3
RSTurbo50
12-02-2020, 01:43 PM
No iv not moved the car as the alarm goes off when I open the doors manually and keeps going off until the doors are closed. Is there any way of turning the alarm off so |I can try to reprogram the keys??
RSTurbo50
12-02-2020, 01:43 PM #4
12-02-2020, 02:17 PM
put the key in the ignition and turn it on, the alarm should turn off then
12-02-2020, 02:17 PM #5
RSTurbo50
12-02-2020, 05:44 PM
Sparkystav put the key in the ignition and turn it on, the alarm should turn off then
Again iv tried this and started the car but the alarm still sounds....
Running out of ideas here..
RSTurbo50
12-02-2020, 05:44 PM #6
12-02-2020, 05:47 PM
That's very odd, is the battery ok?
12-02-2020, 05:47 PM #7
RSTurbo50
12-02-2020, 06:12 PM
Iv had the car for a week, no problems until Friday evening. Parked it up about 6pm, went to go out in it as 7pm, couldnt get in it and the fob just wouldnt open the thing up..
Battery seems fine. I can get in the car opening it manually but as I said the alarm goes off until I close the door and then it stops after a while..
Autoelectrician maybe?
RSTurbo50
12-02-2020, 06:12 PM #8
12-02-2020, 06:52 PM
try disconecting the battery and reset all the ecu's on the car try all the simple things first also check all the fuses
12-02-2020, 06:52 PM #9
12-02-2020, 07:20 PM
It's odd the door closing stops the alarm though. Really is stumping me sorry
12-02-2020, 07:20 PM #10
Views 788
08-11-2024, 04:53 PM
Last Post by Keeperlit19
Views 1,181
28-06-2023, 10:30 AM
Last Post by MichaelTTE
Replies 61
Views 6,960
25-11-2022, 04:53 PM
Last Post by john wan
Views 1,697
08-11-2022, 04:46 PM
Last Post by Morango
Views 2,555
22-07-2022, 09:35 AM
Last Post by simon87
Views 972
17-03-2022, 03:46 PM
Last Post by iceman
Views 1,885
17-02-2022, 02:32 PM
Views 1,647
11-02-2022, 05:16 PM
Views 1,639
28-01-2022, 12:06 PM
Last Post by 1374lee
Views 1,781
27-01-2022, 10:17 PM
