JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications eaton m62 clutch
eaton m62 clutch
eaton m62 clutch
196
27-02-2022, 06:58 PM
hi all i am curently in the middle of fitting an eaton m62 supercharger kit and the guy who is doing it is telling me about the charger haveing a clutch and it cant be engaged via the ecu.
there is a cable coming from the charger and i would like to know if this will engage it if it is wired up to battery. or does it need a switch
what is the best way to engage the clutch?
lexusdaydreaming
27-02-2022, 06:58 PM #1
196
27-02-2022, 07:00 PM
for lexus is 200.
lexusdaydreaming
27-02-2022, 07:00 PM #2
for lexus is 200.
27-02-2022, 07:34 PM
Yes there's wires coming from it, you can permanently engage it, but that'll just drain your battery.
So either run it via the ignition so it's only on when the engine is, or attach it to a switch you can turn on when you want, or get a throttle switch so it only comes on when you put the throttle past a certain postion
27-02-2022, 07:34 PM #3
27-02-2022, 07:38 PM
thanks for the fast reply i will have a think but via the ignition seems good to me.
lexusdaydreaming
27-02-2022, 07:38 PM #4
Views 819
26-02-2022, 05:00 PM
Views 1,075
24-11-2020, 07:54 PM
Last Post by Jon
Views 1,071
17-04-2020, 01:26 PM
Last Post by spud1973
Views 681
17-12-2019, 04:06 PM
Last Post by S
Views 695
06-11-2018, 07:04 PM
