JapCarForum Car Manufacturers Lexus/Toyota front drivers side brake calliper wanted
19-03-2022, 11:08 AM
As above . Has anyone got one they are not using anymore.
Or could someone give me some pointers on how to free one up.
My one is sticking a bit and would like to get it sorted /replaced.
Chess Moley
19-03-2022, 11:08 AM #1
Chess Moley
reganlives
19-03-2022, 11:17 AM
You'll be able to get a remanufactured one from a decent motor factors. I got one from andrew page Ltd. They give you some money back if you come back and give them the old caliper.
reganlives
19-03-2022, 11:17 AM #2
is200turbo
19-03-2022, 02:00 PM
I replaced mine for £70 from my local motor factor
is200turbo
19-03-2022, 02:00 PM #3
reganlives
19-03-2022, 03:31 PM
Was similar money for me as well
reganlives
19-03-2022, 03:31 PM #4
is200turbo
19-03-2022, 03:36 PM
Strangely the rear caliper is £110
is200turbo
19-03-2022, 03:36 PM #5
rob
20-03-2022, 01:05 PM
Silicone grease under the boot and work the piston.
rob
20-03-2022, 01:05 PM #6
Phil01
21-03-2022, 03:17 PM
rob Silicone grease under the boot and work the piston.
^^^ true dat
My O/S/R caliper the piston had seized, I pulled back the piston rubber, used an extension nozzle on some spray silicone grease and squirted it for like 30 secs to make sure there was plenty in there, refitted it, drove all ok and now, no more hot brake disc and burnt paint.
Phil01
21-03-2022, 03:17 PM #7
^^^ true dat
Views 949
08-06-2023, 06:16 PM
Views 765
22-04-2023, 08:12 AM
Views 1,001
28-10-2022, 11:23 AM
Views 519
21-03-2021, 06:29 PM
Last Post by Fry-Up
Views 483
06-02-2021, 06:02 PM
Last Post by mattlaw
Views 1,522
20-04-2020, 05:35 AM
Last Post by sprinter2012
Views 1,383
18-02-2020, 04:46 AM
Last Post by Tomo1978
