JapCarForum Car Manufacturers Lexus/Toyota Advice needed, front suspension
lygis
06-06-2023, 04:53 PM
Hi guys,
I have a problem with the front suspension and I have no clue which part it could be so I thought I will try to ask you guys. It is definitely front, driver side and the problem is when you turn the steering wheel even slightly the sound comes like old, rusty, squeaky doors and it is very loud inside the car and even louder outside. Any thoughts appreciated guys. Thanks in advance!
Lygis
lygis
06-06-2023, 04:53 PM #1
Hi guys,
Lygis
07-06-2023, 04:58 PM
Are you sure it's not the power steering mate? Lack of fluid or loose belt?
07-06-2023, 04:58 PM #2
lygis
07-06-2023, 05:03 PM
Fluid level is right in between minimum and max, didn't check the belt, not 100% sure but I think its suspension. Is there any way to find out what is could be? Thanks Sparky
lygis
07-06-2023, 05:03 PM #3
07-06-2023, 05:37 PM
Is it only whilst moving or at standstill?
07-06-2023, 05:37 PM #4
lygis
07-06-2023, 05:44 PM
both moving and standstill, i'll go and check belt quickly, will let you know in 5mins
lygis
07-06-2023, 05:44 PM #5
07-06-2023, 05:49 PM
Sweet
07-06-2023, 05:49 PM #6
Sweet
lygis
07-06-2023, 06:04 PM
belt is fine, fluid level just above minimum. As I said, I think its suspension. Went to the garage last time to check it, but as soon as I got there that squeaky sound disappeared. Its not always there, it appears and disappears occasionally. By the way (not related to the topic) but measured my S/C pulley and its 120mm. Definitely needs upgrading.. Big Grin
lygis
07-06-2023, 06:04 PM #7
07-06-2023, 06:30 PM
Definitely odd! If it's audible at standstill your best bet is just get someone moving the steering while you get your head into the engine bay (carefully obviously) and have a listen about
07-06-2023, 06:30 PM #8
lygis
07-06-2023, 06:40 PM
Will see what I can do tomorrow. Thanks for your time Smile Anyone still make or has bigger pulleys?
lygis
07-06-2023, 06:40 PM #9
07-06-2023, 07:05 PM
Think squint on Facebook has them, but not cheap. Lexuspat knows the part number for the merc pulley that works I think.
07-06-2023, 07:05 PM #10
Views 804
03-02-2024, 01:39 PM
Last Post by theblitz6666
Views 1,563
30-01-2024, 12:47 PM
Last Post by Millo73
Views 436
28-12-2023, 05:44 PM
Views 1,144
19-08-2023, 03:28 PM
Views 520
07-06-2023, 05:46 PM
Views 562
25-01-2023, 02:57 PM
Views 533
13-01-2023, 04:43 AM
Views 1,001
28-10-2022, 11:23 AM
Views 308
25-06-2022, 08:31 AM
Last Post by reganlives
Views 1,395
20-06-2022, 03:23 AM
