JapCarForum Car Manufacturers Lexus/Toyota Suspension Upgrade (lowering)
Dinho
30-05-2023, 05:15 AM
I've ordered some 50mm lowering springs, I would like to know is there anything else I should consider getting changed, I've already been told about lower ball joints. Would it be a good idea to buy new bushes? Car coming up to 70,000 I've had it since 44,000 and never changed them. Just after some useful advice from people who have gone down that route before.
Thanks
Dinho
30-05-2023, 05:15 AM #1
Thanks
FOSSIL FUELS
Moderator
892
31-05-2023, 01:06 PM
Bottom ball joint if going lower... Seen so many fail recently.
[Image: Supra-logo-toyota-supras-119417_1569_512...duxjro.jpg]
Toyota Supra Aero Top... In 202 Black and 18" GOLD & Chrome's with a BGW Wink
FOSSIL FUELS
31-05-2023, 01:06 PM #2
Dinho
31-05-2023, 04:28 PM
I have noticed, would it be wise to change bushes at the same time? Thanks for the confirmation
Dinho
31-05-2023, 04:28 PM #3
FOSSIL FUELS
Moderator
892
31-05-2023, 06:44 PM
Which bushes?
FOSSIL FUELS
31-05-2023, 06:44 PM #4
Which bushes?
Dinho
01-06-2023, 06:35 AM
Track rod bushes I believe someone said
Dinho
01-06-2023, 06:35 AM #5
FOSSIL FUELS
Moderator
892
01-06-2023, 05:43 PM
Track rod ends.
Might as well if your doing bottom ball joints.
FOSSIL FUELS
01-06-2023, 05:43 PM #6
Track rod ends.
02-06-2023, 05:33 AM
A 50mm drop on standard dampers might not actually be much of an "upgrade". Have you got uprated roll bars? Also, make sure you get your wheel alignment done properly afterwards as it makes a huge difference.
02-06-2023, 05:33 AM #7
Dinho
05-06-2023, 04:07 AM
Haven't got uprated roll bars, most likely will go down that route in the future. Yep I will be getting it aligned once fitted. Also someone has being saying that 50mm springs will greatly shorten the life of the standard shocks. So that being said what decent shocks are out there for the is200 I've seen long and bilstein.
Dinho
05-06-2023, 04:07 AM #8
05-06-2023, 05:51 AM
Not sure about bilsteins, spend the money on the roll bars first. It really is a massive difference.
If I were to do another is200 I'd go Meister r coilovers again. They were absolutely fantastic coupled with TRD roll bars. Even more comfortable than standard when set to soft.
05-06-2023, 05:51 AM #9
Dinho
05-06-2023, 07:57 AM
There are few other things that need my money first, being as i've already ordered the springs I think should I just sort out the shocks now if needed, that's the part where I'm struggling with information.
Anti Roll Bars are on the list though
Dinho
05-06-2023, 07:57 AM #10
Views 1,851
27-03-2024, 05:35 PM
Last Post by dougie175
Views 953
08-06-2023, 06:16 PM
Views 535
13-01-2023, 04:43 AM
Views 548
18-08-2022, 06:56 PM
Views 310
25-06-2022, 08:31 AM
Last Post by reganlives
Views 1,400
20-06-2022, 03:23 AM
Views 485
30-12-2020, 09:49 AM
Last Post by old school
Views 797
21-05-2018, 05:51 PM
Last Post by Phil01
