JapCarForum Car Manufacturers Lexus/Toyota Fuel injectors
Fuel injectors
Fuel injectors
Andy_C
22-06-2024, 03:25 PM
I'm looking into getting cheap power out of my standard IS200 so I'm considering looking for bigger injectors, but to do this I've got a few questions to ask.
1) What is the capacity of the standard injectors?
2) I know the ECU is self learning, so will it adjust to compensate for the extra flow of fuel like it does when you install a high flow air filter?
Thanks in advance. Andy
Andy_C
22-06-2024, 03:25 PM #1
22-06-2024, 06:54 PM
You've got the wrong car for cheap power unfortunately.
The ecu will compensate a bit but no where near enough.
How much power you after?
22-06-2024, 06:54 PM #2
Wayne
23-06-2024, 06:51 AM
Would injectors on there own give you a noticeable difference?
Wayne
23-06-2024, 06:51 AM #3
Andy_C
23-06-2024, 07:32 AM
Sparkystav You've got the wrong car for cheap power unfortunately.
That's all I needed to know really. I'm not after a specific number just a bit more omph. As my car has done 170,000 miles I thought maybe the injectors could do with being changed and if they did then is it possible to go with bigger ones to get a bit more power.
Andy_C
23-06-2024, 07:32 AM #4
Andy_C
23-06-2024, 07:35 AM
Wayne Would injectors on there own give you a noticeable difference?
Probably not. I was thinking to change the injectors because they have done 170,000 miles and go for bigger ones because every little helps. But it seems the ecu wont alter the air fuel ratio enough to do it.
Andy_C
23-06-2024, 07:35 AM #5
23-06-2024, 07:40 AM
Getting my injectors cleaned at £190k definitely made a noticeable difference to how mine idles and responds. It's not faster but it's a cleaner quicker smoother response for sure.
23-06-2024, 07:40 AM #6
23-06-2024, 08:39 AM
purplewitch Getting my injectors cleaned at £190k definitely made a noticeable difference to how mine idles and responds. It's not faster but it's a cleaner quicker smoother response for sure.
i was going to suggest the same thing! its not expensive to get them cleaned and can help with any sluggishness
23-06-2024, 08:39 AM #7
Wayne
23-06-2024, 11:25 AM
What is the upgrade on ours? The ZZsomething from a Yaris?
Wayne
23-06-2024, 11:25 AM #8
23-06-2024, 12:04 PM
Wayne What is the upgrade on ours? The ZZsomething from a Yaris?
1zzfe i think
23-06-2024, 12:04 PM #9
1zzfe i think
Wayne
23-06-2024, 01:55 PM
Yeah that sounds right
Wayne
23-06-2024, 01:55 PM #10
Views 1,445
19-03-2024, 03:43 PM
Views 330
28-06-2023, 05:41 PM
Views 508
18-10-2022, 06:14 AM
Views 548
18-08-2022, 06:56 PM
Views 420
19-05-2022, 03:00 PM
Last Post by jeffrosie
