JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Wheel nut/Spacer sizes
bash6673
03-01-2018, 06:25 PM
Need some details here folks.
I've got these wheels getting refurbed at present.
[Image: 33cc9bc.jpg]
They are 17x7J 35 O/S. The PCD is 114.3x5.
I need to buy new wheel nuts,as the wheels were supplied without them, but I'm not sure which ones to buy.
Does anyone know the correct width and length of the thread and any recommendations as to which nuts and spacers to buy.
[Image: 2ziy45c.jpg]
Thanks.
bash6673
03-01-2018, 06:25 PM #1
Thanks.
03-01-2018, 06:28 PM
That is a good question mate. I wish i knew.
03-01-2018, 06:28 PM #2
03-01-2018, 06:38 PM
do you not have the 18 inch aero wheels fitted??why the drop to 17's
03-01-2018, 06:38 PM #3
03-01-2018, 06:41 PM
M12 x 1.5
21mm hex
This is for the standard wheel nut size mate? but you'll have to check if there a flat fitting or domed fitting needed for the wheels?
Looking at the pic, you might need tuner style nuts?
03-01-2018, 06:41 PM #4
M12 x 1.5
21mm hex
03-01-2018, 06:49 PM
oh ps i'm running an offset of 35.......DO NOT USE SPACERS my wheels sit in line with the arch any further out and they'd rub....
03-01-2018, 06:49 PM #5
bash6673
03-01-2018, 07:03 PM
ormi do you not have the 18 inch aero wheels fitted??why the drop to 17's
the 18s are due to be refurbed (as they are in a hell of a mess) once the 17s are back. I also want to keep the 18s for use over the summer (ha!,we get a summer?) and swap over to the others during wimter. method in my madness somewhere.
Bandit M12 x 1.5
21mm hex
M12x1.5 thanks Bandit, that's what I was after.
ormi oh ps i'm running an offset of 35.......DO NOT USE SPACERS my wheels sit in line with the arch any further out and they'd rub....
Sound, I'll try them without,from what you are saying they should be ok.
thanks for the info guys..
bash6673
03-01-2018, 07:03 PM #6
Bandit M12 x 1.5
21mm hex
04-01-2018, 06:50 AM
Yeah I think you'll need the "tuner" nuts too. Maybe it's me, but I used to have no idea what this meant until I went looking for wheel nuts for my Chicanes. These are the nuts that are designed to sit within narrow holes, so they're quite thin and usually come with a special adaptor for your normal socket.
Do check what the seating is on the wheel though, e.g. domed/flat, as Bandit said, this is very important.
04-01-2018, 06:50 AM #7
bash6673
04-01-2018, 03:46 PM
steviewevie Yeah I think you'll need the "tuner" nuts too. Maybe it's me, but I used to have no idea what this meant until I went looking for wheel nuts for my Chicanes. These are the nuts that are designed to sit within narrow holes, so they're quite thin and usually come with a special adaptor for your normal socket.
I checked them today and they appear to be the domed type as it feels beveled.
I take it you mean similar 'tuner' nuts to these?
[Image: 2re5f0x.jpg]
bash6673
04-01-2018, 03:46 PM #8
04-01-2018, 05:33 PM
Yeah, that sort of thing. There are various types that are similar. You need enough clearance to get the nut in and some sort of socket/tool to tighten/untighten it.
04-01-2018, 05:33 PM #9
Views 458
28-08-2021, 01:28 PM
Views 934
31-01-2021, 02:11 PM
Views 196
02-12-2020, 12:37 PM
Last Post by jasons
Views 385
06-09-2020, 05:35 PM
Last Post by Chris0121
Views 775
24-08-2020, 02:57 PM
Last Post by Matt_C
Views 725
07-08-2020, 07:30 PM
Last Post by micromarc
Views 833
01-08-2020, 04:43 PM
Last Post by is300_dino
Views 1,146
01-08-2020, 02:28 PM
Last Post by jasons
Views 966
18-07-2020, 05:24 AM
