JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Unusual wheel protrusion
bash6673
23-03-2018, 08:37 AM
[SIZE="4"]Has anyone seem this before on their car?
My N/S front wheel and tyre appear to stick out further than the O/S wheel and tyre.
The wheels are the exact same as are the tyres. No spacers fitted and the dimensions are identical.
The rear wheels and tyres are identical in that they have the same profile on each side.
These pics were taken from roughly the same angle and height to give you an idea of what I mean.
It is even more noticeable when you look down the side of the car from a head on view.
[Image: mr67ue.jpg][Image: es3vvm.jpg]
The steering and suspension appear to be fine, there are no knocks,rattles or shakes when driving.
Anyone have an idea why the N/S appears to be sticking out further?
[/SIZE]
bash6673
23-03-2018, 08:37 AM #1
[/SIZE]
reganlives
23-03-2018, 08:51 AM
has the car been involved in any accidents? theres a possibility that the chassis may be a bit "bent" but I wouldnt think too deeply into that thought. Get the geo checked on the car and u'll be able to work out more from there.
reganlives
23-03-2018, 08:51 AM #2
bash6673
23-03-2018, 08:58 AM
The car drives perfectly, no wandering across the road etc.
HPI check was clear although it may have had a bump previously and not been declared.
Geo check hopefully will find the solution.
Thanks.
bash6673
23-03-2018, 08:58 AM #3
Thanks.
That does look quite weird, so it's just the front, the rears are fine?
As above has the left front corner been involved in a crash where maybe suspension parts may not have been fitted correctly, or possibly something is bent?
Although if you've had the geo checked recently that probably would have highlighted any physical damage.
23-03-2018, 08:58 AM #4
bash6673
23-03-2018, 09:04 AM
I've had a good look at the suspension set up and all appears to be fine with no hint of any damage being covered up.
[Image: er0sd2.jpg]
[Image: mcxj42.jpg]
Edited 04-05-2010, 01:02 PM by bash6673.
bash6673
23-03-2018, 09:04 AM #5
[Image: er0sd2.jpg]
[Image: mcxj42.jpg]
23-03-2018, 05:05 PM
mate your car is fine.....if you take a close look at the bumper its the bumper thats at fault the tte front bumper wasn't the best fit/made the best.if you look under the bumper you will see a metal bar that goes from the under tray/arch liner to the bottom of the bumper(at the wheel arch) loosen it a wee bit pull the bumper out slightly and tighten it back up that should sort you out matey....ps mine was the same......
23-03-2018, 05:05 PM #6
23-03-2018, 05:08 PM
nice one ormi...
have some rep for that explanation matey
23-03-2018, 05:08 PM #7
nice one ormi...
bash6673
23-03-2018, 07:53 PM
ormi mate your car is fine.....if you take a close look at the bumper its the bumper thats at fault the tte front bumper wasn't the best fit/made the best.if you look under the bumper you will see a metal bar that goes from the under tray/arch liner to the bottom of the bumper(at the wheel arch) loosen it a wee bit pull the bumper out slightly and tighten it back up that should sort you out matey....ps mine was the same......
Cheers Ormi.
I'll have a wee look at it in the morning and sort it out.
Thanks again.
bash6673
23-03-2018, 07:53 PM #8
Cheers Ormi.
Thanks again.
23-03-2018, 08:09 PM
Are you sure? I know the angles of the two photos are different, but still if you ignore the bumper and look just at the wing, on the right you can still see the tyre next to the wing whereas on the left the tyre is well hidden and tucked in behind the wing. It's the same if you look at the line of the wheel with the door mirror...........hope it's just the photo though and just an illusion with the bumper as ormi says Smile
@bash: Can you do a full head on front photo from a few feet back (if this problem is still visible like that)?
23-03-2018, 08:09 PM #9
23-03-2018, 08:39 PM
you will never be able to match the angle you take a pic from side to side so i just think he's a tiny bit further round/closer thats whats making it look like the wing is out or poss could be that some one has leaned against the wing at some point hold the arch close to were the bumper meets the arch and give it a light pull stand back and look do again if needed it wont take much job done its called a minor adjustment of the pannel lol.
23-03-2018, 08:39 PM #10
Views 459
28-08-2021, 01:28 PM
Views 952
31-01-2021, 02:11 PM
Views 196
02-12-2020, 12:37 PM
Last Post by jasons
Views 387
06-09-2020, 05:35 PM
Last Post by Chris0121
Views 775
24-08-2020, 02:57 PM
Last Post by Matt_C
Views 835
01-08-2020, 04:43 PM
Last Post by is300_dino
Views 1,159
01-08-2020, 02:28 PM
Last Post by jasons
Views 968
18-07-2020, 05:24 AM
