JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Wheel arch liner rubbing
23-03-2018, 11:03 AM
I just worked out today what the strange noise was that I sometimes get when manoeuvering my car out of its parking space.
It's the nearside front wheel rubbing on part of the wheel arch liner when it's on full lock.
Does anyone else get problems with this ? I'm wondering how to sort it. Perhaps I can take the arch liner off and bend it a bit ? In the worst case I suppose I could cut it, but that seems a bit drastic. The bit it's rubbing on is sticking out slightly, e.g. I can prod it with my finger and it pushes in (but then pops right out again).
It's only a problem on full lock so it's not exactly the biggest problem in the world.
23-03-2018, 11:03 AM #1
23-03-2018, 11:09 AM
could you not heat it up and remould it slightly?
23-03-2018, 11:09 AM #2
23-03-2018, 11:13 AM
Mmm, yes, that's a good idea.
23-03-2018, 11:13 AM #3
23-03-2018, 11:17 AM
Yeap i get this too, not too bothered though, dont do donuts all day:w00t::w00t::laugh:
23-03-2018, 11:17 AM #4
23-03-2018, 11:24 AM
steviewevie Mmm, yes, that's a good idea.
i do get them every now and again lol glad it helped
23-03-2018, 11:24 AM #5
23-03-2018, 11:45 AM
Yep I remember others doing that after fitting bigger alloys, use a heat gun and then just push it back away from the wheel.
Strange that you're getting the rubbing with the TTE wheels though - does the arch liner look like it's not fitted properly or like it's changed shape?
23-03-2018, 11:45 AM #6
23-03-2018, 12:02 PM
It's probably connected with being lowered. Perhaps also with taking the wheel arch liner off and back on to do the front lip (and then the bumper etc with the turbo install).
There was a noise there before I had the turbo installed, but I think it's got worse since that was done (where the ride height has changed too).
23-03-2018, 12:02 PM #7
TM
23-03-2018, 12:03 PM
check if you have stop bolt,:tongue_smilie:
TM
23-03-2018, 12:03 PM #8
23-03-2018, 12:04 PM
Stop bolt ? :confused1:
23-03-2018, 12:04 PM #9
TM
23-03-2018, 12:11 PM
these stop the wheel from turning too much,on both sides,and can be ajustered,but some car are not fitted with them,
u need to remove the wheel,turn it to full lock and check where it stops
some cars even have a rubber stop on them:Shooting:
TM
23-03-2018, 12:11 PM #10
Views 453
28-08-2021, 01:28 PM
Views 933
31-01-2021, 02:11 PM
Views 195
02-12-2020, 12:37 PM
Last Post by jasons
Views 383
06-09-2020, 05:35 PM
Last Post by Chris0121
Views 774
24-08-2020, 02:57 PM
Last Post by Matt_C
Views 833
01-08-2020, 04:43 PM
Last Post by is300_dino
Views 1,146
01-08-2020, 02:28 PM
Last Post by jasons
Views 966
18-07-2020, 05:24 AM
