JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Window not working
Window not working
Window not working
06-05-2018, 05:15 PM
Was just out a short while ago and my front passenger window wasn't working. I could hear it clicking when I pressed the switch so it wasn't a fuse, but just wouldn't go down.
However I've just got home and tried it again before switching off, and now it's working fine. Was the window just stuck or could it be the regulator on its way out? Anything I can check or just leave it alone and see if it happens again?
06-05-2018, 05:15 PM #1
06-05-2018, 05:19 PM
Maybe a silly question but did you locked the window by mistake ?
06-05-2018, 05:19 PM #2
Chri5
06-05-2018, 05:34 PM
but if the window was switched off would it still click???
Chri5
06-05-2018, 05:34 PM #3
06-05-2018, 05:36 PM
Don't know mate i don't have a IS200 any longer, you could go out and try it mate and let us all know:biggrin:
06-05-2018, 05:36 PM #4
Chri5
06-05-2018, 05:50 PM
nope when the windows off it dont make a noise.
what you got now mate???
what happened to the lex???
Chri5
06-05-2018, 05:50 PM #5
06-05-2018, 05:54 PM
he has an sc430
06-05-2018, 05:54 PM #6
he has an sc430
06-05-2018, 06:04 PM
It would still click if the fuse had blown, as the click is the relay, the fuse is for the motor (which the relay turns on)
And i think it does still click when youve turned the switch off
06-05-2018, 06:04 PM #7
Chri5
06-05-2018, 06:08 PM
mine didnt make a noise at all mate.
Chri5
06-05-2018, 06:08 PM #8
06-05-2018, 06:53 PM
The lock switch was off, but I did check it just in case. I'm pretty sure it doesn't click though when it's on?
Either way it's working now again so it can't be a fuse problem?
06-05-2018, 06:53 PM #9
Views 312
15-07-2021, 12:44 PM
Last Post by Dub///15
Views 720
27-06-2020, 04:32 PM
Last Post by purplewitch
Views 849
16-12-2019, 05:00 PM
Last Post by Barry
Views 1,539
28-09-2019, 05:32 PM
Views 1,172
18-03-2019, 01:44 PM
Last Post by danielson
Views 867
31-10-2018, 11:06 AM
Views 968
17-10-2018, 07:09 PM
Views 648
04-10-2018, 08:24 PM
Last Post by jomo
Views 712
25-01-2018, 04:21 PM
Views 1,915
18-01-2018, 04:41 PM
