JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Main Key not working - Buttons Or Key!
S
26-09-2019, 12:13 PM
Hi all,
I've read the thread about adding another key to the cars system and I have some questions.
Basically my questions are:
What battery do I need for my buttons? (im hopeing its the battery because the problem is very intermittent! If it isn't I don't know what it is!)
How hard is it to have a key cut if I buy a new case?
(my case has snapped so when i try to start the car I have to hold the key very close to ignition or the case just twists. What I mean by the difficultly of getting a key cut is - could any key cutting place do it or is it a main dealer only thing?)
Also when the car is double locked can only the buttons disarm it?
(my car was double locked this morning and when the buttons didn't work I tried the key in the drivers door and the alarm went off - much to the amusement of my nosey neighbor!)
Thanks
David
S
26-09-2019, 12:13 PM #1
Hi all,
Thanks
David
26-09-2019, 01:31 PM
i think the baterry you need is a c1616, small watch type bout the size of a 10 pence piece, think lex charge just over a £5 for replacement and fitting or you can get them from ebay for a lot cheaper, linky to some prices http://www.google.co.uk/search?q=c1616+b...36&bih=772
not had to have a new key cut but as long as the shop has the right cutting equipment any smiths should be able to cut it for you
cant rememebr the trick for the alarm i think you just have to do it like you did and disarm it with the ignigtion but someone else will be able to explain it better if there is another way of doing it.
26-09-2019, 01:31 PM #2
S
26-09-2019, 02:09 PM
Thanks for the battery number Smile
Funny you should mention the dealership price, I called Lexus newcastle and explained the problem and the bloke in the parts fepartment said I needed a whole new key and it would be £90 + vat, hence why I am going to have a go myself!
S
26-09-2019, 02:09 PM #3
26-09-2019, 02:56 PM
omg thats terrible! dont blame you mate you will need a tiny screwdriver to get the case apart.
26-09-2019, 02:56 PM #4
S
26-09-2019, 03:12 PM
Nah mines falling apart! LOL
I'll get a picture up, its wrecked! Lol
S
26-09-2019, 03:12 PM #5
jasons
26-09-2019, 05:36 PM
Get a case from Ebay, get it cut at local place- (around £10) transfer RC bit from old key (replacing battery at the same time).
job done.
J
jasons
26-09-2019, 05:36 PM #6
job done.
J
S
26-09-2019, 06:58 PM
So do I need to re add the key to the system if I remove the battery?
S
26-09-2019, 06:58 PM #7
27-09-2019, 08:06 AM
Don't think so... Fairly sure as long as the battery is changed within a minute or so then you're ok.
As I understand it, the key has its signature, which the car will recognise. Too long without a battery and the key forgets its signature, so can't work the car...
Just change it quickly and it'll be fine :biggrin:
27-09-2019, 08:06 AM #8
S
27-09-2019, 08:24 AM
Excellent! Thanks a lot gents!
S
27-09-2019, 08:24 AM #9
27-09-2019, 02:45 PM
You certainly don't need a new key. The cases and blanks are all over ebay for under a tenner, not all key cutting places can cut them, but most will, for £5-10. If you need to reprogramme it at all, I wrote a comprehensive step by step guide on the matter a few years ago, I can send to you if needed.
27-09-2019, 02:45 PM #10
Views 709
27-06-2020, 04:32 PM
Last Post by purplewitch
Views 1,159
18-03-2019, 01:44 PM
Last Post by danielson
Views 829
06-05-2018, 06:53 PM
Views 1,886
18-01-2018, 04:41 PM
Replies 44
Views 4,280
16-01-2018, 10:46 AM
Replies 33
Views 2,605
05-01-2018, 06:19 AM
Last Post by kam05
Replies 41
Views 2,843
03-09-2017, 02:56 PM
Views 1,111
04-06-2017, 05:11 PM
Last Post by Andy-R.
