JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Turbo timer
Turbo timer
Turbo timer
06-06-2018, 05:17 PM
What turbo timer do people recommend...
i was looking at this ONE
is it worth getting a boost controller also on a turbo car...
06-06-2018, 05:17 PM #1
06-06-2018, 05:31 PM
Not sure if this is overkill mate, but the Gizzmo MS2 is a great bit of kit? but a bit on the pricey side? i had a Greddy one in the skyline and that worked fine :thumbup1: the Gizmo MS2 has both the turbo timer and the boost controller and has a lot of good reports on its accuracy :thumbup1:
06-06-2018, 05:31 PM #2
06-06-2018, 05:42 PM
You dont really need one to be honest rabster, though they are nice to have.
I'd always try and get one with an auto mode so if your going on a long journey it makes sure you really cool it down.
I dont think itll affect your car any more but with the IS you can wire the ign1 and ign2 wires in, though if you wire both the standard remote lock doesnt work, if you wire just the ign1 (i think) the remote lock works but the alternator doesnt charge so its just running on battery for the duration of the countdown.
06-06-2018, 05:42 PM #3
07-06-2018, 11:15 AM
its good to have one
07-06-2018, 11:15 AM #4
07-06-2018, 11:19 AM
Rabs will the turbo timer work with your After market alarm.
As the car needs to continue to run even if you walk a way from it.
You can set the time the engine runs for i guess you already know this.
I am sure your find away to make it work...
07-06-2018, 11:19 AM #5
07-06-2018, 12:40 PM
I wouldn't bother. It's nigh on impossible to make turbo timers work with thatcham installed alarms. I'm pretty sure the Clifford alarms that have built in timers aren't thatcham approved.
As said above, if you're really going to bother (I don't believe they are worth it, having run my car both with and without) make sure it's one with an auto functionality which monitors boost and revs over time and calculates how long to run the engine for.
07-06-2018, 12:40 PM #6
07-06-2018, 12:41 PM
Also presumably you already have some variety of boost controller unless you're just running on actuator pressure? Even if it's just a grainger valve.
07-06-2018, 12:41 PM #7
07-06-2018, 01:07 PM
Thinking of gettin boost controller as well
I like toys with wires to play with lol
07-06-2018, 01:07 PM #8
07-06-2018, 04:18 PM
OOOH looks like i may not need a turbo timer apparently the Clifford G5 Range come with one as standard.......
hmmm how do i turn it on lol
07-06-2018, 04:18 PM #9
08-06-2018, 05:54 PM
if i was going to go for a alarm would go for the clifford g5 or a viper system.
08-06-2018, 05:54 PM #10
Views 1,077
16-04-2024, 09:39 AM
Views 529
29-11-2023, 09:27 AM
Last Post by phaebo
Views 922
24-07-2023, 08:07 PM
Views 1,357
19-06-2022, 06:39 PM
Replies 24
Views 2,246
17-09-2021, 12:12 AM
Last Post by warhead3005
Replies 24
Views 2,541
05-02-2021, 01:22 PM
Views 1,238
03-10-2020, 06:40 PM
Last Post by jimxms
Views 1,906
11-02-2019, 09:21 AM
