JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications charger help
charger help
charger help
liquidlazer
12-02-2019, 07:37 PM
Hey guys recently fitted an AEM digital boost gauge on my car and most of the times the boost from the charger is only showing 2psi max cant get it to move past that. Some times it reads 1psi then goes up to 2 psi. i Check all the hoses dont seem to find any of them slack. Any ideas as to why i cant make the 4psi. here is a pic of the bypass valve dont know if it is set up correctly
[Image: photo19.JPG]
liquidlazer
12-02-2019, 07:37 PM #1
13-02-2019, 04:20 AM
Maybe your belt is sliping. try to tighten the belt.
13-02-2019, 04:20 AM #2
Rolex
13-02-2019, 09:37 AM
spray a can off easy start around all of your couplings while the car is idling and listen for the engine tone to change. this will help you as certain boost leaks. or you can try washing up liquid and water ina spray bottle. spray it on the couplings and look for the bubbles.
Rolex
13-02-2019, 09:37 AM #3
15-02-2019, 06:20 PM
A way i found a boost leak on mine was to close the bypass by hand at idle,
When you close it, it fills the pipework with pressure, and you'll hear it if its leaking? don't hold the bypass closed for long though, just enough to see if you can hear air escape from the system? You could spray each hose joint with soapy water and check each one for bubbles one at a time?
15-02-2019, 06:20 PM #4
edeath
21-03-2019, 02:00 PM
Yep i did the same as Bandit on mine listen for the hiss - was leaking from IC joiners. Also maybe try a 5pk790 belt rather than 5pk800 as well. Should be seeing 4.3-4.4 PSI on the guage if its all ok.
edeath
21-03-2019, 02:00 PM #5
rob
08-04-2019, 05:46 AM
liquidlazer Hey guys recently fitted an AEM digital boost gauge on my car and most of the times the boost from the charger is only showing 2psi max cant get it to move past that. Some times it reads 1psi then goes up to 2 psi. i Check all the hoses dont seem to find any of them slack. Any ideas as to why i cant make the 4psi. here is a pic of the bypass valve dont know if it is set up correctly
you have the old type of bypass spring...... i have no idea if toyota motorsport can still supply the upgrade kit, if not i would contact bermani as they do have the kits but it will cost you, amount unknown.
rob
08-04-2019, 05:46 AM #6
spud1973
16-07-2019, 06:09 PM
I have the same bypass spring and mine has just broke going to measure the spring and get one here. Bermani seems to be hard to get hold of.
spud1973
16-07-2019, 06:09 PM #7
rob
19-07-2019, 01:20 PM
spud1973 I have the same bypass spring and mine has just broke going to measure the spring and get one here. Bermani seems to be hard to get hold of.
they are very easy to contact, i have spoken with them a few times in the last weeks and they answer the phone after just a few rings, they have someone on the desk all the time.
rob
19-07-2019, 01:20 PM #8
Views 1,535
14-11-2024, 05:18 AM
Replies 168
Views 13,997
03-07-2023, 08:45 AM
Views 1,005
30-03-2022, 09:15 PM
Views 754
13-03-2022, 11:27 PM
Last Post by deccie22
Views 703
07-06-2021, 06:18 AM
Last Post by reganlives
Views 1,472
15-04-2021, 06:59 PM
Last Post by S
Views 984
24-11-2020, 07:54 PM
Last Post by Jon
Views 1,283
24-11-2020, 06:07 PM
Last Post by argyle dan
Views 1,416
14-08-2020, 08:51 PM
