JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Sluggish throttle opening
RichyUK
26-04-2019, 03:33 PM
Hi guys, not sure if its normal or not, but with the igntion on, if you full the throttle open quick with the cable, the DBW part lags quite a bit behind, hence the **** throttle response!
If this is normal is there anyway of adjusting? i wonder if the Greddy Ultimate has any settings for it...
RichyUK
26-04-2019, 03:33 PM #1
26-04-2019, 05:07 PM
change it all to a manual throttle? lol
26-04-2019, 05:07 PM #2
RichyUK
26-04-2019, 05:22 PM
Sparkystav change it all to a manual throttle? lol
if its possible i'll do it Big GrinBig Grin
was just a bit shocking to see how slowly it follows the cable!
RichyUK
26-04-2019, 05:22 PM #3
26-04-2019, 05:30 PM
unfortunately without a more complex ecu than the ultimate youd struggle
26-04-2019, 05:30 PM #4
26-04-2019, 07:35 PM
what about the throttle add on mod or is that just for 300's? where you put a plastic spacer from a radio controlled cars suspension or a chunky zip tie over the spring to cancel the effect of spring between peddle and cable giving much better response,
26-04-2019, 07:35 PM #5
RichyUK
27-04-2019, 07:08 AM
is300_dino what about the throttle add on mod or is that just for 300's? where you put a plastic spacer from a radio controlled cars suspension or a chunky zip tie over the spring to cancel the effect of spring between peddle and cable giving much better response,
ah, so basically fixing the DBW part to the 'normal' throttle part?
RichyUK
27-04-2019, 07:08 AM #6
RichyUK
27-04-2019, 07:19 AM
ive checked that mod, thats a different thing Smile
Edited 08-06-2011, 11:07 AM by RichyUK.
RichyUK
27-04-2019, 07:19 AM #7
27-04-2019, 07:20 AM
yeah it just basically kills the dead spot i thought there was a thread on here but i cant find it there is one on myis.com but looks like the pictures have died heres a link http://my.is/forums/f62/is300-throttle-c...er-350180/
27-04-2019, 07:20 AM #8
Views 1,285
06-06-2020, 07:50 AM
Last Post by S
Views 621
22-12-2019, 07:42 AM
Last Post by Talisker
Views 3,693
30-08-2019, 08:26 PM
Views 837
10-12-2018, 09:10 PM
Last Post by Phil01
Views 774
10-10-2018, 02:46 PM
Views 358
09-10-2018, 11:30 AM
Views 827
30-07-2018, 07:19 AM
Last Post by Hogan22a
Replies 23
Views 2,016
25-12-2017, 06:07 PM
Last Post by ormi
